Page 1 of 2
A contact No for RUSTRITE in sydney
Posted: Mon May 18, 2009 7:55 pm
by Harko
Hi all , I am in need of the number for a Rustrite , He is/was a guy that delivered rust repair sections to sydney , Wollongong.
He may even supply rare spares
Have misplaced his number and cant track him down.
Posted: Thu May 21, 2009 8:25 pm
by oldnek
Harko, I've been trying ring that guy for months, his mobile is disconnected, no other contact numbers. So don't know whats happened to him.
Posted: Thu May 21, 2009 8:28 pm
by Harko
Well Ive got great news for you .
Rustrite ph 0414478052
Hes delivering a front left and two rear floorpans to me at the desalination plant tomorrow
I guess Ill be busy on the coup over the weekend , the tunnel turns up tuesday ..
Posted: Thu May 21, 2009 8:56 pm
by parisian62
Hi Harko,
Can you tell us more abour rustrite? Have they got a shop? Do they press their own panels/rust sections? Are they cheaper than rares?
Stewart
Posted: Fri May 22, 2009 3:12 pm
by swivel
Hi Harko,
Does this guy make lower rear Quarter Rust repair panels?
Swivel
Posted: Fri May 22, 2009 7:35 pm
by Harko
Today I bought two rear and a front left for $85 each delivered .
His price seems a little exorbident to previous purchases .
Im pretty sure he supplies rares but these seem a thicker grade of steel than rares ones .but still inherit the flaws.
His van had all makes of cars signwritten on it so I presume he does most makes and one offs.
Swivel I actually asked that exact question and he said he could make it but didnt stock it ..
Posted: Fri May 22, 2009 9:05 pm
by parisian62
thanks Harko. Are you still chasing a rear door? what side?
Posted: Fri May 22, 2009 9:23 pm
by Harko
I am , a right rear , Im heading up to the blue mountains early tomorrow then back to colyton , if you have a nice clean one buzz me 040 333 0880 and Ill see if I can swing across town .
Posted: Fri May 22, 2009 9:39 pm
by parisian62
I've got a few doors down the back of the shed. will check it out in the morning and let you know.
Posted: Fri May 22, 2009 9:57 pm
by Harko
Thanks Stuart
Posted: Fri May 22, 2009 10:35 pm
by matches
does rustrite do complete panels (guards ect) or just rust repair sections? sounds good that they're a thicker grade steel though.
Posted: Sat May 23, 2009 8:11 am
by parisian62
I have one. It looks pretty clean. Has been resprayed at some time and the trim holes welded up. There are 2 small rust spots both about the size of 5c piece. Have left my mobile number on your mobile.
forgot to add...it has no glass.
Posted: Sun May 24, 2009 7:46 am
by EK283
Harko,
Could we see a photo of the repair sections (floors). I have bought several types and hate the pressings cause they just don't fit right including rares. I found a nos rear right and it was a perfect fit. Still have the rear left to do but not happy with the pans I have bought.
Posted: Sun May 24, 2009 8:26 am
by Harko
They are identical to rares in that respect , the rears seem ok so far but the fronts look hammered into shape in areas where I know they are pressed , Ive fitted them before aswell and I know exactly where you are coming from .
I acheived the best results by teck screwing the floorpan into position - pulling the offset swages to where they should be then cutting along inbetween the screws and welding , then removing the screws cutting and welding the rest , then welding up the screw hole .
Hmm sounds like alot of extra work to utilise a poor design huh.
Posted: Sun May 24, 2009 5:27 pm
by parisian62
Hi Harko,
Did you want that door?
regards
Stewart
