Hey People!
I'm looking for the specs of an original FB.
Weight in particular, I can't find the weight on the net anywhere!
Does anyone know the dry weight of an FB?
-- Rowan
Specs?
Rowan,
I'm not sure about dry weights but the FB Holden Shop Manual states the following kerb weights:
FB/215: 2473 lbs
FB/225: 2494 lbs
FB/219: 2605 lbs
FB/229: 2627 lbs
FB/2104: 2559 lbs
FB/2106: 2479 lbs
Transmission weights (dry) are 374 lbs for engine/flywheel/clutch and 454 lbs for engine and transmission.
I hope these are of some help to you. I'll let you do the conversions (2.2 lbs to 1 kg)
Hayden
FB/215: 2473 lbs
FB/225: 2494 lbs
FB/219: 2605 lbs
FB/229: 2627 lbs
FB/2104: 2559 lbs
FB/2106: 2479 lbs
Hayden
1960 FB Special Sedan
FeeBee
FeeBee
