Is it as simple as it looks?
To remove fuel tank:
undo screwy things inside the boot...
take the plug off that connects to engine
yank the bitch outtt
actually, hold the yanking thought - do u lift the tank out? and how do you get the filleryuppery tube thingo out of the body?
Hi J did this a couple of months ago.
Drained the tank.
We cut the fuel sender wire before removing (hope that wasn't a mistake!) , remove the cap then the rubber on the outside from the 'filleryuppery tube thingo'.
Take the fuel line off and screws like you said.
And when you take it out - lift it up and out then towards the front of the car to get it clear.
Drained the tank.
Wasn't the smartest way. Undoing the nut on the sender which attaches the wire might have been a little bit more time consuming but will save having to rejoin the wires later! Also just at a guess why Holden out it there in the first place....TimR wrote: We cut the fuel sender wire before removing (hope that wasn't a mistake!) ...
1. They shouldn't be smoking or drinnking in the car anyway.J wrote:i gots two problems.
people in the back seat after I fill up the car tend to get a lil crazy and laugh a lot.
and yeh fuel gauge doesnt work
2. Use a 138, they go forever on the smell of an oily rag. (or fill up daily) The guages didn't work when they were new, so keep it standard.
