Enginee bay photos
Posted: Thu Mar 12, 2009 7:19 pm
by SHREK72
Today I tried to start my vehicle for what I am led to believe is 7 years. I only bought it recently and are having all sorts of problems.
Does someone have a photo of the linkage setup to the carby as mine just does not work. Last person who owned it had wire controlling the throttle and I don't think that is original. Mine just won't start.
Also it has a massive spark running from the craby to the firewall. Any ideas as to why??
Had the car for 2 months and not being able to start it is killing me.
As always thanks for your help.
Posted: Thu Mar 12, 2009 7:24 pm
by Trev
The spark is the motor earthing out on the body through the linkage, what you need is an earth from the battery to the body to stop this, Trev
Posted: Thu Mar 12, 2009 8:43 pm
by SHREK72
Thanks Trev but already has one from the battery to the body near the radiator...Spent the last hour running an earth from just about everywhere still no success..............Decided to hire a trailor and take it to Auto Electrician....
Thanks for the advice Trev
A very frustrated Rodney.
Posted: Fri Mar 13, 2009 8:53 pm
by V8EK4us
Shrek,
As Trev said "what you need is an earth from the battery to the body to stop this, Trev" ...... BUT, before you take it to an auto elec', check the earth to the motor, the motor should be well earthed otherwise it will not run (good size earth cable from motor to body.... same size as a battery earth would be good).
Carby link should not stop it starting, have a mate "pump" the carb a couple of times and she should fire up.
As a guide: Ignition, Fuel, Air..............
1/ You need spark ....... you have this (although it might be travelling the wrong way - due to bad engine earth)
2/ Fuel, are the carby jets blocked? can you smell fuel when you pump the carby?
3/ Air, very are that the air filter is that blocked that a motor wont at least start ....
Posted: Fri Mar 13, 2009 9:52 pm
by Cal
Shrek, if you want I can bring mine around for you to look at the linkage setup.........I'm not too far from you.
Though right now it's still sitting at the mechanic's
Posted: Fri Mar 13, 2009 10:32 pm
by dave68
Yer I saw it today.....Nice.
