How do you replace? undo side trim? I had a little fiddle and could feel some big stick things in there...
does that mean I dont need glue?
Headlining - whats the go?
Those stick things J are hood lining bows. They each have a particulr spot they need to be in too, so don't mix them up if you pull them out. The hold the lining up.
You definitely need glue and both front and rear screens out to do it properly. I had mine fitted by a trimmer as we tried but decided we couldn't get it in as well as a trimmer would. The trick is to get it tight very evenly. Then you don't get wrinkles.
