cam specs
Posted: Fri Aug 22, 2008 8:31 pm
by matches
i have got crow cam and i don't know how "hot" it is. can anyone help? what info do you need?
any help would be great.
L&K
Posted: Fri Aug 22, 2008 10:30 pm
by Craig
Hey Matches if it has the part# stamped on it try this
http://www.crowcams.com.au/media/catalo ... %20HYD.pdf
Posted: Fri Aug 22, 2008 10:58 pm
by matches
its in the engine but i do have the opening and closing specs.
Posted: Sat Aug 23, 2008 7:08 am
by FB MAD
Give 'em a call and tell 'em what info you have re open/close specs, they may have enough info there to give you the rest of the specs unless it is a one off customer spec grind on the cam.
Posted: Sat Aug 23, 2008 9:39 am
by matches
i'm mainly wondering how people come up with like 30/70 cam, ect . people ask me what cam i have and i don't know how to determine that terminology
Posted: Sat Aug 23, 2008 10:07 am
by Thommo
Gday matches
The 30/70 numbers are a referance to the timing of the inlet valve opening & closing position in degrees*.
ie; Inlet valve starts to open at 30*, finished closing at 70*
Standard cam has timing of about,
Inlet 9*-52*
Exhaust 48*-12*
30/70 cam would be something like,
Inlet 30*-70*
Exhaust 70*-30*
Hope this helps.
Jeff
Posted: Sat Aug 23, 2008 10:27 am
by matches
thanks thommo, that is exactly the info i was after.
my cam is an inlet: 30/70
exhaust: 79/31
would this cam be rather lumpy? hard to drive?
L&K
Posted: Sat Aug 23, 2008 10:35 am
by Thommo
Yep, its a big cam.
My FB runs a 35-75 on a heavily worked engine, see specs........here
A internally stock engine fitted with twin carbs & extractors,
might run a 16/56 cam which is mild.
30/70 is for a hotty.
Jeff
Posted: Sat Aug 23, 2008 11:14 am
by matches
cool, how is it to drive? it looks hot, and i love the grandpa "sleeper" look.
mines got a 186 and aussie 4 speed so i'm hoping it'll be pretty quick.
i just hope i don't drag the chassis out from under the caravan :lol:
L&K
Posted: Sat Aug 23, 2008 1:22 pm
by Thommo
It go's well (for a grey)
I had it dyno'd and had the distibutor recurved so it behaves beautifully.
It has a lumpy idle, doesn't splutter or stumble at low speeds,
revs up quick and screams when I stand on it.
Its probably only as quick as mild 186 though,
but it looks and sounds cool 8)
Jeff
Posted: Sat Aug 23, 2008 1:34 pm
by matches
very 8) , i do like the look of the greys, but my dad knws reds so i went with where the knowledge was. thanks heaps for the help, can't wait to be able to meet you all.
L&K
Posted: Mon Aug 25, 2008 1:35 pm
by Sammy
my mate has the crow cam in his engine, its not to bad but it comes on a bit later than i would choose for a street motor, i recommended he choose the next one down but he reckons bigger is always better :)
