unbolting guards
Posted: Thu Aug 07, 2008 2:00 pm
by paroharo
this is a rookie question :oops: but I need to ask it..
where else - apart from in the engine bay - do you need to unbolt the front guards to remove them?
I'm guessing maybe behind the kick panel in the cabin?
Is this right and are there any others?
cheers
Jon 8)
Posted: Thu Aug 07, 2008 3:29 pm
by matchew
if you have a look inside your wheel arch with the wheel off you will see up towards the front the guard will be joined to the front beaver, and obviously the bumper bar will have to come off and besides what youve already mentioned i cant think off anything else off the top of my head
Posted: Thu Aug 07, 2008 6:00 pm
by t950cat
im sure there are some behind the kick panels :?: :?: :?: :?: Tony
Posted: Thu Aug 07, 2008 6:24 pm
by matchew
yeah there is, i thought he mentioned that in the first post but then realized he was more askin if there was, so yes there is.
Posted: Thu Aug 07, 2008 6:28 pm
by paroharo
thanks mat,
I should have mentioned I already have the bumper, grille and beaver panel off.
the main thing I'm asking about is the part of the guard that's flush with the front of the front door, how is that secured to the car?
Posted: Thu Aug 07, 2008 6:29 pm
by paroharo
...and as I'm replying, the answer appears!
excellent thanks guys
Posted: Thu Aug 07, 2008 6:31 pm
by matchew
actually forgot to mention (although im not sure) but if its the same as hg there will be one or two on the outside joining it to or near the sill panel
Posted: Thu Aug 07, 2008 7:05 pm
by karsten
i think theres 4 half inch heads nead socket with exstention long one,,,,,,,, in the inside of front pillar ,,theres 2 on the bottem rear of guard to body ,,the support bracket in the wheel arch has two,,, and underneath between stone tray and guard,,, once all are out pull gaurd away from body at the bottom rear of gaurd in front of door and pull it out and upwards which helps it go forward , they can be flexed alot,,, make sure the bumper and support rod are undone bumper gone,,, disconnect head light wires first and poke the grommet and wires through the inner gaurd ,,, and just work her loose :lol:
Posted: Thu Aug 07, 2008 8:57 pm
by blue ute
Tip - stuff a rag at the base of the 'A' pillar cavity to catch anything falling from your socket & disappearing, & it will - same for re-fit,
