SCATCH PLATE QUESTION.
EK DAZ
Post by EK DAZ »
Hi there folks, I have just collected a set of FB/EK door scatch plates from different sources. Are these able to fit on any door on the car or do they fit in certain places? I have noted that one has " LF '' on one of the little tabs, but the rest are un- labled. Any help on this would be great. Thanks.
EK DAZ
Giveitall
Post by Giveitall »
I put a set on my wagon which had LF LR RF RR
on the tabs. So I put them in those positions accordingly.
Didn't obviously try them in other spots so can't completely
answer your question, however they did all look vefry similar!
To put them on you only need to loosen the handles from the
inside with a large phillips screwdriver and they should just slip
into the gap.
Hope that was some help to you :)
EK DAZ
Post by EK DAZ »
Yes ,thanks.As you say,I cant see any physical difference in these plates at all. Regards Daz.
EK DAZ
blue ute
Post by blue ute »
There's 2 kinds, one has a chrome centre & the other has a frosted centre, I would say the ones without LF LR RF RR on the tabs would be aftermarket & not original nasco, they are marked because of the slight differences in door contours between the front L/R & rear L/R doors.
TAYZ 58
Post by TAYZ 58 »
FWIW,
I put a dob of sicaflex on each of mine cause they can come loose, and are too bloody hard to replace!!!
