removing cam gears
Posted: Sun Jul 06, 2008 4:30 pm
by matches
i've got a red 186 and i just bought a new cam and timing gears, my problem is the gear won't come off the crankshaft. help?!
Posted: Sun Jul 06, 2008 4:42 pm
by rosco
Hi Matches,
I replaced mine two years back - it had to be pressed off - and the new one pressed on - I would suggest replacing both (they come in a set) or you will quickly wear the new one by using the old one -
I had an engineer do mine - I don't trust any of my local garages - one day, I'll get a press...
Posted: Sun Jul 06, 2008 8:40 pm
by matches
thanks, i wasn't sure if my "japanese screwdriver" was big enough or if i was doing something wrong...... which i was, i was trying to do it myself
Posted: Mon Jul 07, 2008 1:29 pm
by Sammy
the crankshaft gear should have holes in it to allow the puller bolts to go into it .... camshaft is press only ....
Posted: Wed Sep 10, 2008 10:10 am
by autobilly
As the other guys have said, use a puller to get it off. It's hard but be persistant. As for getting the new one on, I didn't see anyone say, but (as an old Grey motor Ace once told me) you can knock it on with a big hammer and drift. I have done this (with care) and it didn't need to be pressed. Don't go too far!
Posted: Wed Sep 10, 2008 1:32 pm
by Sammy
further to that .... put the gears in the oven on about 100 degrees for 20 mins or so then quickly run them out to the shed and bang them on, makes the job alot easier!
Posted: Wed Sep 10, 2008 6:50 pm
by karsten
yeah i used a sledge and a mate with a big drift,,,,,,,,,bang,
use the right puller ,,, three bolt one,,,repco is the go,, i think that was the 202 but reds are the same maybe
