help , EK sedan replacing front springs
Posted: Sun Jun 01, 2008 12:55 pm
by AL
Help , i have taken old springs out when I jack up lower control arm, i cant bline it ut with the bush. When I jack up the arm it keeps on moving across about 1" .. :? :? :? :?
any ideas
Posted: Sun Jun 01, 2008 3:39 pm
by FB MAD
Sorry Al but not sure what you mean by "i can't bline it ut with the bush".Not trying to be a smart a#*e but just don't know what you mean.
Posted: Sun Jun 01, 2008 6:13 pm
by AL
All done FBM. the wishbone wouldnt fit back over the the 2 lugs that are mounted on the either side of the crosmember, had to line up back one first then the front with a lot of persuasion.
Ended up using a siscors jack on an angle from the back of the drum to the floor jack to line the wishbone with crosmember.
I hope the springs drop they were 2" lowered only droped 15mm
Any advise of a better way ?
AL
Posted: Sun Jun 01, 2008 8:52 pm
by FB MAD
The springs/front end kind of settles a bit after fitting and a few runs so you'll find the front end may lower a bit more over time than the 15 mm that it's dropped so far.Although I'm not sure whether it will drop another 35 mm to give you the 2 inch drop the manufacturer has said :? .
See how it goes, the worst thing that can happen is you have to remove the spring and cut off another 1/2 to 1 coil from the spring to get your 2 inch drop your after :evil: .
