steering wheel restoration
nashspeedno85
Hi all just wondering if any one knows of some one that can restore steering wheels in melbourne thanks.
Just did my own
, I'm not saying it will be a show job but it wasn't hard to do at all. This is what I did (refer to cruisin on ch 31).
1; Open up all cracks down to the steal with a dremal type of tool with a grinding stone attatchment.
2; Drill holes diagonally into the cuts, for the filler to key into.
3; I used a product called "Kneed it", it's a two part filler that sets hard as a rock in about 30 minutes.
Follow the instructions on the pack.
4; Press it into the grooves so that it goes into the holes aswell, so that it is also a bit proud of the serface.
5; When hard, sand to the original shape of the wheel and viola, Done.
6; Paint it any color you want.
Like I said not hard at all, Trev
Yeah I've done a few in the last year or so.
With the cracks, open em up real big with some coarse sandpaper. Then I use Kahfill (fibreglass bog) and once have that all in shape, hi fill primer...a few coats, sand and paint... if you want something a bit fancy maybe take it to a panel beater/rod shop....
artyfartymarty
- State: WA
The centre cover is a press fit, just carefully prise it off with something like a screw driver, some steering wheels are hard to get off so a puller is the best way to remove them without wrecking the wheel
, Trev
