Moderators: reidy , Blacky
mattymartin
Posts: 841 Joined: Fri Oct 06, 2006 12:49 pm
Post
by mattymartin » Thu Feb 28, 2008 6:22 pm
hey guys,
ever since i saw that van the mini's with the KRAAAAAAAZY cuctom dash, i've developed a dash obsession...
check out some of my photoshop creations below...
hey, has anyone else ever played with the idea of customise the cluster configuration...
matty martin
mattymartin on Fri Apr 18, 2008 7:58 am, edited 1 time in total.
go the wagons....
(AUST)Mod
Posts: 2272 Joined: Sun May 07, 2006 11:16 pm
Post
by (AUST)Mod » Thu Feb 28, 2008 6:29 pm
Should have filled the extra blinker holes in Photo SHop :p
Craig wrote: Andrew you have a red so I wouldn't race it
mattymartin
Post
by mattymartin » Thu Feb 28, 2008 6:58 pm
i thought you could use one of the old indicator chrome thing to house a red alarm lamp in the middle one...
matty martin
go the wagons....
spyder6052
Posts: 400 Joined: Mon Nov 26, 2007 9:56 pm
Post
by spyder6052 » Fri Feb 29, 2008 12:50 am
top one would be good for putting a tacho in
also needs a clock....
retro
Posts: 848 Joined: Wed Apr 25, 2007 9:15 pm
Post
by retro » Fri Feb 29, 2008 9:42 am
matty does two speedos mean you can go twice the speed?
i reckon it would be a wild customisation if you can fit the additional gauges ie water temp, oil, tacho, and clock.
Posts: 3687 Joined: Mon Feb 05, 2007 4:42 pm
Post
by Thommo » Fri Feb 29, 2008 12:08 pm
Its got me thinking
I have all the parts
Harko
Posts: 2387 Joined: Fri Apr 07, 2006 9:36 pm
Post
by Harko » Fri Feb 29, 2008 12:38 pm
You will have a little trouble welding the fascia's together ,They are cast
Post
by Thommo » Fri Feb 29, 2008 1:08 pm
Harko wrote: You will have a little trouble welding the fascia's together ,They are cast
I was thinking of glueing them together,
as it is going to have a painted finish anyway.
Mephious
Posts: 626 Joined: Thu May 10, 2007 10:01 pm
Post
by Mephious » Fri Feb 29, 2008 6:49 pm
Nice thinking Matty.
I personally think the FB/EK dash is the nicest dash in the entire Holden range, would be a shame to cut them up.
....... that said, hahaha what about just three little ones like your white backing dash Matty mounted upside down for oil, temp and boost ? Use the flat edge to the dash base in the center above the gearbox hump ? Maybe a metal surround 10mm thick on all edges but top, folded edges and painted the dash body colour ?
One blinker hole would make a good spot for a recessed shift light.
(AUST)Mod
Post
by (AUST)Mod » Fri Feb 29, 2008 7:29 pm
Mephious wrote: Nice thinking Matty.
Now thats a COOL idea
Smooth customs
Posts: 771 Joined: Tue Nov 28, 2006 3:51 pm
Post
by Smooth customs » Fri Feb 29, 2008 8:02 pm
Guys, this is not a hard thing to make
Have made similar parts during proto type development work I have done over the years
A fibreglass mould has to be made of the standard part.
And then two products are made from the mould
Cut and join, finish off the surface joins .
Then have it electroformed
Sputzwagon
Posts: 2708 Joined: Fri Dec 07, 2007 6:27 pm
Post
by Sputzwagon » Sat Mar 01, 2008 11:39 am
A slight change to the above...
PLUS CLOCK!
Woofto Car Club Member No 2
mattymartin
Post
by mattymartin » Mon Mar 03, 2008 6:04 am
nice one scotty...
go the wagons....
retro
Post
by retro » Mon Mar 03, 2008 7:49 am
hey thommo, sounds like theres nuthin that superglue cant fix hey?
matty, i still reckon ed (fe wagon) mastered the dash customising, shame our fb/eks had to be cast.
Post
by Thommo » Mon Mar 03, 2008 9:35 am
retro wrote: hey thommo, sounds like theres nuthin that superglue cant fix hey?
'Arildite' Retro, Im old school
