Diff Pinion Angle?
Diff Pinion Angle?
Gday Members
Quick question.....Is the 'Pinion Angle' the same on Early Model Holdens, FB to HR
If so, what is it?
Thanks
Jeff
Harko
Post by Harko »
Ive just set up a diff the other night Thomo , EK pinion angle is 2.75 degrees .
\Not sure if the HR is any different ,I believe they are all set at 3 or around 3 degrees
When I set up the big block in the ute I set it at 3 degrees also
Thanks Harko :wink:
Does anybody have the facts about the different models though?
