Hq-wb Commodore stud patern
nashspeedno85
Post by nashspeedno85 »
Hi all just wondering if any one out there can tell me if hq-wb stud pattern and commodore are the same i always thought they were but someone has told me opposite. Any help on this topic would be much appreciated.Thanks.
Post by mrs ratbox »
they are very close i think commodore is metric or something, you can put commodore wheels on to hq
munro
Post by munro »
the difference is verry little.
if you use wheels with standard nuts there's no problems but if you use the old style of mag nut you'll bend the studs
the threads are also different
cheers tom
captainbill
Post by captainbill »
Be carefull centre hub sizes are different and can be hard to get the wheel back of.
oldnek
Post by oldnek »
Holden Commodore is 120mm pcd and HQ to WB is 4.75 inches in the old scale. Or 120.65 mm.
The centre hole on the Commodore rim is smaller than the HQ series.
The HQ rims shouldn't be fitted to Commodore stud pattern, the taper on the seating face of the rim and nut taper will no be seated correctly, and you can have vibration problems, rim cracking and fatigue on the wheel studs> I mean it is only common sense.
John
nuts
I'll go along with John,
Something is nagging me about metric vs imperial - remember Rod Hadfield telling me something when I spoke to him about disc calpers but.........?
I have a commodore diff in the EK, it has been narrowed and the bolt pattern changed to HQ . Because there is only .65mm difference in the PCD, I offset drilled the stud holes to HQ pattern and fitted oversize wheel studs from Coventrys .
This gives you HQ stud pattern without having to weld and redrill the axles and only costs about 15 bucks for a set of wheel studs.
Dr Terry
Post by Dr Terry »
munro wrote:the difference is verry little.
cheers tom
Hi munro.
You will still bend the studs with 'standard' wheel studs. As you tighten the nuts into the tapered hole, the stud will then bend outwards. I've lost count of the number of broken wheel studs I've replaced because of this problem. With the barrel type mag wheel nuts, you often can't even screw them into the holes, without forcing them, depending on how loose they are in their hole.
The other difference between HQ & Commodore style rims that's often forgotten is their different offset. The Commodore rims will reduce your wheel track dimension considerably & sometimes they will foul suspension arms or rub brake hoses.
Dr Terry.
nashspeedno85
thanks for all the comments guys much appreciated im selling a set of simmons on evilbay and as usual im having dramas with smart ar@#$%$ but thanks again guys for your help im sure this information is use full to allot of people including me.
