(cue howls of horror from those who want to stay original)
Will be going to red engine, HR disc front, Celica 5spd (all pretty standard and proven mods).
This'll mean I'll start with ripping apart my EH ute and re-conditioning each part piece by piece until I've got everything together to do the conversion on the EK.
Will begin with the engine (it's a 179HP that has been a great lil motor for me already), give it a full re-build and warm it up a little.
At the same time, get the twin Strommies re-conditioned (or buy a new set), extractors and manifold blasted and coated, and electronic ignition overhauled.
When that's done, the HR front end can come out for full re-conditioning. Still doing some research to see whats the best way to set this up for EK...want to run 14s and get lower than the car currently sits (any advice from those that have done this already??).
Gearbox is a beaut...never had a problem with it, so will just see what might need doing when that's out.
Once this is all go (which will be a little while seeing as it'll cost some $$), I'll start looking at taking the EK off the road and doing the actual conversion, with all required mods to tunnel etc.
Might even get the horn working...lol
Couple of questions that I have:
1. The diff is original - with this conversion in mind, would I need to be looking at changing that to match the front gear, or is it ok to run as is with required mods (keeping in mind that I'll need to fit 14s on the rear)
2. Will the EK radiator be ok with a warm red, or should that be swapped for something else
3. See question above re. best way to set up the HR front for good ride height and wheel size etc.
The work begins in three weeks when I have a couple weeks off work and can start things moving on the EH gear.
Cheers, Scott
