Can any one shed some light (Sorry about the pun.) on my dilema.
Should the Drivers (RHS) front parking light be brighter than the left?
The bulb is a dual filiment type 20/5w,
RHS park light is 20w and LHS park light is 5w
Both indicators are 5w.
Swapping the wires on the LHS acheives same result.
Harko,
thanks for your prompt response. Is all new wiring, Did it myself following (I thought.) the existing wiring plan and wiring diameter as closly as possiable.
The problem doesnt seem to be voltage loss, just the wrong filiment illuminated
Yep, the indicator has to be the brightest one and should light up the larger/longer of the two filaments in the bulb.
Going on the bulb wattage figures you've given the park lights should be the 5 watt and indicators should be 20 watt.
I would check your earths or ground connections, the other possibilty would be that the centre connector on the globe socket could be broken and the tangs that locate it are in fact sheared off.
