Wiring a new temp guage.
Pabloek
Post by Pabloek »
Hi guys, come to pick your brains again. 👍 I'm fitting a new temp guage and not sure if I'm way off track or not. Haha. Can I combine the orange white and red and run them to the resistor as shown in pic. Then I've earthed the black at the guage end and the sensor end (as far as I can tell..) and the green I've hooked up to the red on the sender....
It illuminates but the guage doesn't get off 40.....
Like I said, I'm very non qualified but can usually figure stuff out.... 😂
Any help would be appreciated!
Cheers guys
Re: Wiring a new temp guage.
Red wire from gauge should go to positive on coil, or ignition terminal on key barrel.
Yellow wire to main feed on light switch or direct to battery. Consider a fuse here.
Black wire to gauge mount ,earth to body.
Green to sender on the donk.
White with the grey on the dash light feed on the side of the light switch.
Pabloek
Post by Pabloek »
Ah.. Thanks mate! Appreciate it!
Pabloek
Post by Pabloek »
Next stupid question. 😂
Just something like this with a 5 amp fuse enough?
Screenshot_20241215_212504_Samsung Internet.jpg (163.76 KiB) Viewed 14556 times
Yes. Or you could run off the cig dome horn circuit from fuse box. That is unswitched fused 12V.
Dr Terry
Post by Dr Terry »
It's not a good idea to use the ignition supply to the coil as a 12V for the gauge.
Depending on how your ignition is wired, the coil doesn't get a full 12 V.
You mention that you wired the gauge to the resistor "as shown in pic". What pic ?
I can see that you have wired a black wire to the negative terminal of the coil, which can't be right.
Where is your ballast resistor located ?
The reason that the gauge needs 3 different 12V supplies, is one is for the memory (colour selection etc.), one is to switch the gauge on & the 3rd is for illumination. Nothing wrong with putting the ignition & illum. wired (red & white) but I would be using a 12V supply (battery or somewhere in the dash) for that.
Dr Terry
Yes, I only suggested the coil because the photo showed a connection slready, which I assumed would be positive. My FB and EK with original and reproduction wiring both get in excess of 12V at coil positive feed it later models differ I know.
Dr Terry wrote: Mon Dec 16, 2024 7:35 am It's not a good idea to use the ignition supply to the coil as a 12V for the gauge.
From memory, the positive side of the coil has some funky voltage behaviour too as the coil charges then unloads. Not as screwy as the way the secondary voltage dances around, but probably enough to play merry hell with delicate electronic gauge internals.
Rob can probably describe this a lot better than I can, but the mental picture I have is that with the points open the coil sees battery voltage (assuming no ballast resistor), but with the points closed and current flowing the coil sees (battery voltage minus coil primary wiring voltage drop).
Dr Terry
Post by Dr Terry »
Errol62 wrote: Mon Dec 16, 2024 11:41 am Yes, I only suggested the coil because the photo showed a connection slready, which I assumed would be positive. My FB and EK with original and reproduction wiring both get in excess of 12V at coil positive feed it later models differ I know.
Original wiring for FB/EK will have a full 12V at the coil, but Red motors do not !
I notice that your coil is labelled "USE WITH EXTERNAL RESISTOR", meaning it needs a ballast resistor & therefore around 8-9 volts is required at the coil, not 12V. Also that terminal you speak of is labelled negative, so not a positive 12V.
Does your car burn out the points regularly, or does it have electronic ignition ?
Dr Terry
The picture supplied by the OP is his coil. I didn’t look too carefully at it I admit. Certainly shouldn’t have anything temp gauge related connected there!
I have been running a 45kV output rated 12V coil with Bosch electronic distributor from VH. 13.9V measured at coil positive when running.
Pabloek
Post by Pabloek »
Hi guys, yeah the old cheap guage my bro in law fitted was connected to the negative of the coil.. It was shitty and never read accurately (from the above I can see why!) Haha. I'm gonna follow Errol62 advice and go red (and white) from ignition behind ignition barrel..
I'll keep you guys posted.. I'll no doubt have more questions that'll cause a cringe or two. 😂
Again, thanks guys, I appreciate the help. 👍
Pablo.
Pabloek
Post by Pabloek »
Hi guys I've got it all wired up correctly now as per advice and it's working but it's always about 12 degrees cooler than what the thermo fan sensor is showing.. both probes are in the same adaptor on the top hose... Not sure why they aren't showing the same temp... Thermo probe seems right as that's always around 80 to 85 but the guage is 68 / 73...?🤔 Any ideas? 😊
Can we have a picture of the sender installation please Pablo?
Do you mean the fan comes on at those settings or are you reading a gauge on the fan circuit. It is possible your fan if set at 82 is causing the motor to run cold as indicated by the gauge. Is the fan constantly running, or only when stationary or moving slowly under load?
