FB/EK Door card stainless trim lengths.
stinky
Post by stinky »
Tidying up my trim shop the other day I came across a bunch of FB/EK stainless, I'll assume most are anyway.
Is someone able to run a tape measure over the various trims so I can sort them out and put them up for sale?
Re: FB/EK Door card stainless trim lengths.
Can do tonight mate.
funkyscooter
Post by funkyscooter »
Is that the set up on Gumtree at the moment? I am missing some trim off my ek sedan rear door cards so I'm keen. Just not keen enough to become the proud owner of all 26 pieces. I can run a tape over what I have and let you know if Blacky doesn't beat me to it.
Scott
funkyscooter
Well my memory is shot - it’s the fronts I’m missing the top trim for.
Pictures might help my description
Front
Rear
Rear Top Back Side
Rear Top Back.jpeg (625.42 KiB) Viewed 10478 times
Rear Top Front Detail
Rear Top Front Detail.jpeg (1.03 MiB) Viewed 10478 times
Rear Top Corner Detail
Rear Top Corner Detail.jpeg (654.27 KiB) Viewed 10478 times
Centre Trim Profile
Centre Profile.jpeg (524.25 KiB) Viewed 10478 times
Assuming the cards I have are EK…..
Rear Top Trim 766mm x 6mm on the front, 16.5 on the back and there with a 90 degree radius at each end. Width is roughly 6mm
Rear Centre Trim - 652mm x 12mm. Radius at both ends and approximately 4-5mm high
Front Centre Trim - 415mm x 12mm. Radius at both ends and approximately 4-5mm high
Front Upper Trim - Missing. Sure someone else can help. As a rough guide, based on the indent in the vinyl on one card, it looks to be 6mm on the front and 16.5 mm on the back- same as rear cards. The trim is straight for 520mm and curves for 400mm to meet the centre trim.
Scott
stinky
Post by stinky »
funkyscooter wrote: Mon Nov 18, 2024 1:17 pm Is that the set up on Gumtree at the moment? I am missing some trim off my ek sedan rear door cards so I'm keen. Just not keen enough to become the proud owner of all 26 pieces. I can run a tape over what I have and let you know if Blacky doesn't beat me to it.
Not me, I'm not sure what I have at the moment.
funkyscooter wrote: Mon Nov 18, 2024 2:23 pm Rear Top Trim 766mm x 6mm on the front, 16.5 on the back and there with a 90 degree radius at each end. Width is roughly 6mm
Front Upper Trim: 926mm long x 9.5mm wide. Radius at trailing (horizontal run) edge, leading (vertical run) edge is open.
stinky
Post by stinky »
Thanks everyone, anyone run a tape over their FB stainless?
stinky wrote: Wed Nov 20, 2024 7:19 pm Thanks everyone, anyone run a tape over their FB stainless?
Have put a reminder in my phone to do it tonight for you Stinky :thumbsup:
stinky
Post by stinky »
funkyscooter wrote: Mon Nov 18, 2024 2:23 pm Well my memory is shot - it’s the fronts I’m missing the top trim for.
I've got a pair, not sure of condition, I can send a picture if you are interested.
Fb front -
Rear
funkyscooter
stinky wrote: Wed Nov 20, 2024 8:01 pm
Yep very keen, please send pics.
Thanks
Scott
stinky
Post by stinky »
Blacky wrote: Wed Nov 20, 2024 9:59 pm Rear
Thanks Blacky, is that first Rear picture correct? Looks like the front card again.
Sorry , my bad - about 590 and 750mm for the rears mate
