Page 1 of 2
Duo servo front brakes
Posted: Thu Oct 31, 2024 8:34 pm
When I applied to put a 179 in FB ute, Vehicle Standards SA only requirement was that I fit self energising, or as GMH called them, duo-servo 1 3/4” front brakes, such as EJ EH. I went ahead and installed the entire HR front end with solid discs, and never looked further into fitting the EJ brakes. Until now.
Ardiesse had mentioned that he was thinking of bolting up HD kingpin front assemblies to early upper and lower control arms. The HD HR front brakes are 2 1/4”, so 1/2” wider than FB EH, which is the reason behind changing the wheel centre design at HD.
Later on I was told that the EJ EH brakes would bolt up to FB stub-axles, making the conversion relatively easy. Now I am wondering if the HD kingpin backing plates will bolt up to FB EK stubs. There are distinct part numbers for left and right FB EK and EJ EH HD kingpin steering knuckles. So it seems feasible to assume that if EJ EH front brakes will bolt up to FB EK steering knuckles. Result is self energising front brakes with an extra 20% braking surface over stock.
Re: Duo servo front brakes
Posted: Thu Oct 31, 2024 8:44 pm
As an aside, I have a hr balljoint front end, with drum brakes, which I am going to swap to disc stubs. So the front drum brakes are sort of surplus. My friend has a sporty FB wagon, and we got all excited that the hr brakes were going to bolt up to it. Friend is now in search of HD front assemblies. In a way I’m glad because I can use a lot of the parts to put together a set of 2 3/4” rear brakes as per HD HR commercial.
Unfortunately the 2 3/4” drums are not available new after market, which could be a limiting factor to this upgrade.
Posted: Fri Nov 01, 2024 6:42 am
Some info below on the steering arms, from my post on putting the Mitsi vented disks onto the kingpin front end:
viewtopic.php?p=229694&hilit=db005#p229694
Excerpt below:
- Early Holden steering arms.jpg (464.85 KiB) Viewed 14772 times
Posted: Fri Nov 01, 2024 9:15 am
Thanks Harv,
I’m still in the dark about whether the HD kingpin backing plates will bolt up to FB steering knuckles.
I did pick up a JB1217 master cylinder at Bendigo last year.
Posted: Fri Nov 01, 2024 9:44 am
by ardiesse
Clay,
An editorial change first: HD/HR front drum brakes have 2-1/4" width linings, EJ-EH are the same width as FB/EK at 1-3/4", although EJ/EH brakes are duo-servo and FB/EK brakes are semi-huck.
I have an HD front drum brake, with backing plate, stub axle and upright. So I can check the interchangeability of parts. From memory, FB/EK stub axles have two through holes - the lower ones, and two threaded holes - the upper ones. EJ-EH and probably HD king-pin stub axles have four through holes. Ken McLean alerted me to this after I found a "rogue" king-pin and upright assembly with all through holes on the stub-axle. I thought it might have been early FE, but Ken said it was most likely EJ/EH.
You'll need to replace the FB/EK steering arms with EJ-HD steering arms, and then there are a couple of ways forward: bolt the HD front backing plates onto FB/EK stub axles, using two shorter 3/8" UNF bolts at the top to go into the threaded holes in the stub-axle, or . . .
use EJ/EH uprights and stub axles on the FB/EK front suspension, and bolt the HD front brakes to the EJ/EH stub axles.
Posted: Fri Nov 01, 2024 10:54 am
Thanks Rob. I knew you’d come to the party. It eill be easier for my mate to stick with his FB stubs.
Posted: Fri Nov 01, 2024 11:00 am
Steering chuckles are common across EJ HD kingpin, so should work.
I will let Gary know to get the steering arms along with backing plates. I need mine to use with the disc stub axles.
Posted: Fri Nov 01, 2024 11:14 am
I corrected my original post to the lining widths thanks Rob.
I can’t quite get my head around the need to use the later steering arms, considering the backing plates fit the original stubs.
Posted: Fri Nov 01, 2024 1:05 pm
by FireKraka
Hi Clay you can use the HD/HR Drum Brake stub axles to fit disc brakes you just need to modify them a bit and bolt on adapter plates I have a pair here that I had on Frank before I went to drop spindles, they take VN/VP front discs and calipers and can be modified again to take VT twin piston calipers as I have done.
Not sure if I'm going to use the modified Stub axles or use drops spindles once again for "The Reverend"
Posted: Fri Nov 01, 2024 1:23 pm
I’m going to run the tried and true stock HR discs thanks Neil. I’ve got all the hardware, even the backing plates. Even got nos caliper kits and bearing kits. These drum spindles are surplus if anyone wants them.
Posted: Fri Nov 01, 2024 4:32 pm
by ardiesse
Clay,
You wrote, "I can’t quite get my head around the need to use the later steering arms, considering the backing plates fit the original stubs."
Yes, they do, but -
In FE-EK brakes, the braking effort from the primary shoe is taken by the big anchor bolt at the 6 o'clock position, and then transferred to the stub axle via the steering arm, because the anchor bolt goes through the steering arm. The components are dimensioned so that the anchor bolt is as short as possible, which means that the steering arm sticks into the brake assembly quite a way, almost to the plane of the brake shoe webbing.
In EJ-HD king-pin brakes, the anchor is now moved to the 12 o'clock position, above the slave cylinder. The bottom of the brake shoes, where the adjuster now is, is free to move. This feature allows the braking force generated by the leading shoe to be transferred to the trailing shoe, increasing the self-servo action. In these brakes, the braking effort is transferred from the anchor pin to the stub axle via the backing plate. This is why EJ-onward backing plates are so much beefier than in FX-EK. And the change in brake geometry necessitated a redesign of the steering arms: no need for the anchor bolt hole in the steering arm, but also, because of their shape, FE-EK steering arms will foul EJ-onward adjusters and backing plates.
Hence Harv's steering-arm diagram above.
Posted: Fri Nov 01, 2024 6:54 pm
Thank you sir. I get it now. I recommended he get the entire drag link and pitman arm etc for a steering upgrade while he is at it.
Posted: Sun Nov 03, 2024 3:30 pm
by oldgrey58
Hi Clay,
In regard to your original post, were Vehicle Standards Ok with the mix of duo-servo brakes on the front and the original semi-huck at the rear?
Is there any concerns with the different operating arrangements of the duo-servo and semi-huck?
Frank
Posted: Sun Nov 03, 2024 8:34 pm
Going on what they specified for the 179 Frank yes. Quite pragmatic I thought, seeing the front brakes do most of the work. They might be a tad more liable to lock the fronts up first I suppose. An EH rear axle wouldn’t be a bad thing but it is extra work.
Posted: Sun Nov 03, 2024 9:37 pm
Might be a good upgrade for the ute - It has Torana rear brakes as it is
