New brakes locked on
A club member contacted me today about this, so scrolled back about 10 years with no luck finding another occurrence on here.
His mechanic overhauled the brakes, including new linings. He drove the car home and parked it in the shed, in gear , handbrake on, as you do. 2 weeks later went to drive the car, lo an behold, rear bakes seized.
Speculating that the lovely fresh surfaces on the drums and linings have stuck,and just need a shock. But how best to do do without causing any damage? I'm sure this is not uncommon.
Speak o Oracle, I implore you.
Re: New brakes locked on
Jack up car
Place on axle stands
Remove rear wheels
Belt around circumference of drum with gympie
Start car , place in gear and drop clutch
At least one should free up , give the other one a few more quilts with the gympie then refit wheels and try the clutch dump trick again.
Once free take back to mechanic with a medium sized pineapple and some lube.
Option 2:
Jack up car
Remove rear wheels
Heat circumference of drum with MAP gas torch
Start engine, engage reverse, let clutch out
If no joy, apply more heat until the brakes begin to free up
Don leather gloves and remove smoking-hot brake drums
Re-adjust brakes
(gift for mechanic as suggested above)
Thanks fellas
