Plastic reservoir for original clutch master
Has anyone got a plastic reservoir for the original clutch master cylinder in good condition they are willing to sell? I have a resleeved master but only a metal can which I would like to replace with a clear tank.
Thanks, Brett
Re: Plastic reservoir for original clutch master
Reckon I’ve got a spare one you can have Brett. I’ll have a look.
Thanks Clay. I have a few but they are all for a larger diameter thread.
Ok, I'll make sure it is the smaller diameter one.
All the reservoirs I have are the same thread. They fit this original HD clutch master so these are the later type.ImageInside thread diameter is 1 1/8"Image
There was an aftermarket plastic reservoir (PBR?) for the early master cylinders. They're a bit hard to find, though . . .
Thanks for looking Clay. Hopefully something will turn up. Part of a few changes to Project 2🤔
I guess you are running the earlier type Brett.
