Page 1 of 2
Glove box mod.....A simple how to
Posted: Thu Aug 02, 2007 8:39 pm
by Devilrod
Ok as promised, my glovebox.... Rather than clog up another thread I decided to do a how to..... enjoy and if anything is not clear ask away
It is nothing more than some panel steel hit with some rattle cans. Really easy to make.
Step 1. Make up a paper template using the original inside of the glovebox. Check it fits..
Step 2. Lay it out on the panel steel.
Step 3. Trace around it (I got lazy and used a spray can).
Step 4. Carefully cut around the edges.
Step 5. Place in bender and start to fold (
or in my case a very crude version of a bender!)
Step 6. Once all bent up weld and frind off edges for a smooth finish, bog and sand if necessary.
Step 6. Drill holes, trial fit, cut necessary holes for gauges, stereo etc..
Then paint and re-install.
Voila!
A good way to keep your dash clean and free of out of place gadgets...
Posted: Thu Aug 02, 2007 8:50 pm
by Alex's EK
nice work, ill get started on my own one tomorrow (maybe). Also where did you put the speakers, have you got photos of that. i was thinking of building fibreglass pods on the kick panels, but maybe not if i can hide them better
Posted: Thu Aug 02, 2007 8:56 pm
by Devilrod
I've only got rears in the shelf no fronts as yet. I have got some old kick panels out of my FC which are all molded etc.. but they're in black carpet.
Posted: Fri Aug 03, 2007 10:39 am
by NoMAD
Looks good DR....
pain in the arse checking that guage i would imagin' unless you got a passenger....
which im sure there would be no shortage of them in you chariot!
NoMAD
Posted: Fri Aug 03, 2007 10:47 am
by Devilrod
Its very easy to see from a normal driving position, but seeing as everything works as it should the gauge is almost redundant. Its nice to have car that doesn't run hot in traffic!
Although I did toy with making the insert deeper and sitting the gauge in the side so I could see it easier, wasn't needed.
Posted: Fri Aug 03, 2007 1:19 pm
by parisian62
G'day Devilrod,
great tech thread - thanks for posting up and sharing.
regards
Stewart
glove box mod
Posted: Fri Aug 03, 2007 4:29 pm
by oldfb6
G'day everyone, very nice looking glovebox set up, another good spot if your a non smoker for your temp gauge which is closer is the ashtray, just fit some sheet metal with hole cut for gauge, cheers Craig
glove box mod
by oldfb6
Re: glove box mod
Posted: Fri Aug 03, 2007 4:52 pm
by smooth
oldfb6 wrote:G'day everyone, very nice looking glovebox set up, another good spot if your a non smoker for your temp gauge which is closer is the ashtray, just fit some sheet metal with hole cut for gauge, cheers Craig
That is a great idea and I have seen it in action. Can't do it to mine because I have a monster living in there!
Regards, Smooth
Posted: Fri Aug 03, 2007 7:41 pm
by Devilrod
Mine's got the switch for the heater fan! Also the cigarette lighter still works.
Posted: Fri Aug 03, 2007 8:14 pm
by smooth
Apart from the monster living in my ash tray I have a working cigarette lighter that I remove to plug my NASCO Remington 12V/240V shaver into.
My stereo is well hidden in and behind the spare wheel well. I have a Sony CD head unit and a Sony 10 Stacker and it is all controlled by a remote twiddler. Speakers are 3 way Kenwood's inside 1960's Dive-in speaker cases with individual speaker volume controls. (Front or Rears - just depends on where you place 'em) LOL
Regards, Smooth
Posted: Fri Aug 03, 2007 8:40 pm
by Devilrod
Sounds like a real neat install there smooth care to share some pics?
I like hiding stereo's in cars, my Hotrod has no visible signs of having a system in it till you turn it on. I have it under the seat and use a remote control. Speakers are all hidden due to no way of locking the car, only setback in owning a roadster...
Posted: Sat Aug 04, 2007 12:06 am
by smooth
Mate, never taken a picture of it! Will do someday and post the pics. BTW I should have typed Drive-In not Dive in speakers. LOL
I can tell you it ain't much to look at as all you can see once you lift the spare wheel floor is the face of the CD Player and the door of the CD Stacker. They are mounted in the area behind the wagon fuel tank/spare wheel just in front of the rear shock mounts. If you look in the back of a wagon you will see a small area of floor between the lift out floor and the back seat it is all under there. I remade the floor and routed lines into the timber for the power cables and speaker cables before replacing the upholstery back over the top. All the wires exit under the rear seat and then to the speakers or along the kick plates to power.
My dash has a NASCO Air Chief manual tune radio with Rola Speaker under the dash as per original. Recently I acquired and new old stock Ferris FM converter that allow the original AM radio to play FM stations. I just have to get around to fitting it.
Regards, Smooth
Posted: Sat Aug 04, 2007 8:28 am
by MINT62
nice one devilrod
that tidy's things up
I too have a g/box mounted cd/mp3 player
just the thing for those long roadtrips
cheers ray
Glove box mod - a simple how to
Posted: Sat Aug 04, 2007 8:59 am
by Malcolm
Devilrod,
What a great idea, but I wish people would stop showing me all their good ideas, I'll never get this car finished.
Mal
