Rear seat fit
Orange Betty
Rear seat fit
Post by Orange Betty »
Hi all, numpty question coming...
This is the rear seat compartment
rear seat floor.jpg (60.07 KiB) Viewed 9031 times
How neatly is the FB/EK rear seat supposed to fit here - this is mine
Rear seat fit1.jpg (73.96 KiB) Viewed 9031 times
Rear Seat fit2.jpg (91.48 KiB) Viewed 9031 times
I would think it would fit neatly on, in or over that main structure bit across the floor. Hopefully as you can see, mine does not.
Maybe it isn't the original seat as it is black and doesn't match the backrest which is
Rear backrest cover.jpg (63.62 KiB) Viewed 9031 times
Which does match the front seat.
Any advice?
Dave
62 EK Sedan in slow progress
Re: Rear seat fit
thats not an original seat base mate, how does it look with the top half removed ? Does it go further back and fit nice around the wheel arches ???
Re: Rear seat fit
Got a rear seat here Dave. Wilma's original.
Orange Betty
Re: Rear seat fit
Blacky wrote: Mon Jan 17, 2022 7:14 pm thats not an original seat base mate, how does it look with the top half removed ? Does it go further back and fit nice around the wheel arches ???
Hi Blacky - it doesn't fit any better with the backrest removed. Just kinda sits half on/off the side of the seat support structure and overhangs the front of it.
Dave
Orange Betty
Re: Rear seat fit
Brett027 wrote: Mon Jan 17, 2022 7:24 pm Got a rear seat here Dave. Wilma's original.
Hi Brett, thanks will txt you :thumbsup:
Dave
Orange Betty
Re: Rear seat fit
Ok, mystery solved. Back seat definitely NOT FB/EK. FB/EK seat courtesy of Brett (and Wilma) is top and right in pics below. Very different seat structure and slightly wider allowing it to fit over the seat rail thing.
Seat structure compare.jpg (79.48 KiB) Viewed 8977 times
Seat compare.jpg (75.42 KiB) Viewed 8977 times
It fits.jpg (67.88 KiB) Viewed 8977 times
I needed to figure out where the seat sat in the seat well cos as you can see I have to make a new one.
seat well.jpg (81.76 KiB) Viewed 8977 times
The seat well has a kink down in it across some of the beads towards the front which will be difficult to replicate. But as the seat doesn't make contact below that kink it won't have to be perfect.
Dave
