Headlights
- BILLY BLACKARROW
- State: NSW
Headlights
I know that i am jumping all over the place in my build just trying to sort things as they come to mind. But wot after market headlights are you using as i am old I need good Headlights possible Led at the moment my parkers which are LEDs seem brighter than my Headlights. I am using seal beam at the moment which are Sh** 50/75
Thanks everyone
Thanks everyone
BILLY BLACKARROW
Re: Headlights
Wagon has H4 halogens, 130/90s. The reflector buckets bolt up, easy relay wiring. Bright enough that you would think I am scared of the dark
Graces ute got the halogen bulbs that slip into the original reflectors. Low enough current that they do not need a relay, but good and bright.
Re: Headlights
I’m pretty impressed with my original Bosch headlights, though globes are only about 45w. Halogen globes would wake them up.
Re: Headlights
This is where I got the halogen bulbs with the base to suit early-Holden reflectors. Looks like Anthony does LEDs too:
http://www.classicandvintagebulbs.com/
Re: Headlights
Yes, thanks Harv. Handy to me.
Re: Headlights
I can't get my head around using halogen when you can use LEDs if you are looking for strong lights. The amount of heat generated and current used is massive in comparison. Is it because you can't get bulbs to suit reflectors?
Re: Headlights
it's mainly because I am old, and still think halogen is the bees knees
LED is probably better for headlights, but I have no experience with it. I've dabbled with LED taillights and instrument lights, with mixed success. Taillights are OK, dome light is awesome, but instrument lights don't give enough beam spread to light up the back of an instrument (or shifter detent position) too well.
Re: Headlights
I'm old too Harv, but LED headlights, if you can fit them, they are game changing.
- State: SA
Re: Headlights
Hi Folks
I have done the H4 halogen upgrade in my sedan by going with new headlight glass/reflector. I have used 55/60 watt, 55/100w & 90/130w globes.Upgraded wiring / relays are a must and eliminate voltage drop via the original dip switch as my original dip switch just operated the relays. A new fused feed was taken off the starter motor. An auto reset circuit breaker would be better, however my mod was c1984. Running a stock generator had trouble keeping up with the 90/130w globes in city traffic.
In my Ute I run original headlight units with the halogen globes on original bases & original wiring. They are ok and can be a quick upgrade.
I have also played around with LED in my motorcycle (single headlight) and they vary quite a bit.
Left LED - poor quality in terms of light volume (lumens) and beam. Hi & Lo is only effected by dimming the output. As such when you go to high beam you don’t see further down the road. Not recommend.
Middle - This one runs on 6 volt which is unique (not an issue with your FB or EK) but great for 1936 vintage bike! Also available in 12 volt. A lot more LED’s, more light but same as above with hi/low beam.
Right - The best of my sample by a mile. Light output is huge and a much more concise light output concentration. Two LED’s for low beam and third LED for high beam. Don’t believe eBay description that it runs on 6 volt (reason for purchase) because it doesn’t work! Fixed that with a Buck Tranny though, anyway no probs at 12 volt. My only experience was the life of unit, one LED failed then another. The best of my trials.
LED globes can be easily adapted to fit old headlight units (as I have done on English bikes) and would be worth pursuing. Ultimately depends on what your requirements are in the end. Hope this helps.
- 0B85B392-A70A-4866-9121-EDF2079C0466.jpeg (595.17 KiB) Viewed 19699 times
- 13890293-BA17-482D-8407-8FFF470DD641.jpeg (524.79 KiB) Viewed 19699 times
Re: Headlights
Thanks Stephen. My tip for LED headlights is that nothing without the inbuilt fan and heatsink is suitable.
Re: Headlights
Sounds complicated.
Like you old farts drive your pride and joys at night anyway.
Re: Headlights
You mean we old farts I think
. Actually LED headlights arw pretty much plug and play. No need for heavy wiring or relays either. You can almost tell I think they are pretty good
- BILLY BLACKARROW
- State: NSW
Re: Headlights
I am leaning towards Led Because I have led's in the rest of the car Ied's dash /tail / flashers / park but Headlights have me stumped I don't know if I have to run relays or not and which one's to get to make it easy for us old folk someone please tell me what to do
BILLY BLACKARROW
Re: Headlights
Some of us doErrol62 wrote: Thu Oct 07, 2021 5:23 pmLike you old farts drive your pride and joys at night anyway.
- State: SA
Re: Headlights
Billy
You wont need relays for LED. As you have sealed beam units you are going to need headlamp shells that accept replacement bulbs.
Depending on the headlamp shells you get will dictate what type of lamp base you need. From there the easiest way is to get the LED bulbs from the link Harv posted.
