Page 1 of 30
WRAY T96 SUPERCHARGER refurb and install
Posted: Fri Feb 14, 2020 9:15 am
by FJWALLY
Thought I would create a separate thread to document this process - hope thats ok
Harvs Wray anecdote will give a lot more detail on the history of Wray - this is more on my journey for the rebuild and fitting to the EK ute
I purchased a T96 Wray from a fellow enthusiast who had it among his collection but had no need for it - it had not been run for a very very long time and bearings and vanes were worn out and we later discovered it had been dropped on the pulley end and had a bent shaft - bummer
This is how I bought it minus the SU carb
Re: WRAY T96 SUPERCHARGER refurb and install
Posted: Fri Feb 14, 2020 9:55 am
by FJWALLY
Posted: Fri Feb 14, 2020 10:02 am
by FJWALLY
Posted: Fri Feb 14, 2020 10:06 am
by FJWALLY
The blower was put back together and tested - will post a link to vid later but sounds pretty good
Posted: Fri Feb 14, 2020 10:17 am
by FJWALLY
For the drive Fred recommended a twin belt same profile as the fan belt to keep it looking period and symmetric so we took a powerbond harmonic balancer and machined it to take a stock pulley of desired size which looks ok
To fit this on I hit the first couple of hurdles
1. The fan would be in the way of the twin belts so it has to move forward towards the radiator at least 20mm - going to do this with a spacer - easy peasy
2. Now the fan moved forward The radiator gets in the way so plan is to modify the top radiator support to allow radiator to move forward 20mm - I will then have the four mount tabs on radiator cut off and new ones welted on that move rad forward 20mm and upwards 10-15mm so it clears the stone tray base plate - I will then cut the vertical lip off the stone guard so rad can sit on top of stone guard - there is actually a little recess in the stone guard that follows the line of the radiator so done neatly this wont even look out of place - just have to check clearance of rad cap to bonnet before making those cuts but think there is enough clearance not to be an issue
Posted: Fri Feb 14, 2020 10:24 am
by FJWALLY
Another issue was space for the S/C as it would interfere with battery - SO I made the first sin in cutting out the battery tray and relocating battery to the tub behind cabin under the floor - seams happy there and I can still charge via the alternator positive and large body earth on front clip - works a treat with no heat build up anywhere i could find
Posted: Fri Feb 14, 2020 12:02 pm
It's going to look very cool I'm sure Rob. Bet you've outlaid a few bills to get there. Good effort keeping it looking period.
Relocating the battery is a worthwhile mod in any car even otherwise stock.
Posted: Fri Feb 14, 2020 1:11 pm
by NoMAD
thats going to be sweet
Nathan
Posted: Fri Feb 14, 2020 7:03 pm
by FJWALLY
Errol62 wrote:It's going to look very cool I'm sure Rob. Bet you've outlaid a few bills to get there. Good effort keeping it looking period.
Yeah its not a cheap process but Fred is being very generous with his time - I would not be able to even attempt it without his skills and sending it to a shop would of made it completely unrealistic cost wise.
Losing the battery certainly cleans it up a bit
Posted: Fri Feb 14, 2020 7:06 pm
by FJWALLY
Its on its way back to me so I can get it painted - just manifolds to go
Posted: Fri Feb 14, 2020 7:11 pm
by FJWALLY
Posted: Fri Feb 14, 2020 7:18 pm
by gpi
are you doing any oiling mods to support the forced induction?
Posted: Fri Feb 14, 2020 7:20 pm
by FJWALLY
Not planning to - Fred doesnt seam to think its necessary - this one wont be spooling up to crazy rpm - I will keep an eye out for a nice oiler anyway
Posted: Fri Feb 14, 2020 7:37 pm
by gpi
water/methanol injection?
Posted: Fri Feb 14, 2020 7:43 pm
by FJWALLY
gpi wrote:water/methanol injection?
Never say never but I want to be able to drive it often so it wont be big boost - pretty big pulleys
