Carby parts wanted
Carby parts wanted
Has anyone got the bent rod that goes between the choke and throttle that increases idle when choke is activated? I'm after 2. Thanks.
Re: Carby parts wanted
I've probably got them, but won't be home until this time next week to check.
Remind me then if you are not successful in finding two in the meantime.
Thanks Harv. Much appreciated.
Much easier to find one than make one.
When I was a young bloke, I broke that arm... and made one up using fencing wire... drilled the holes in them... it worked.
Years later, I put the red in and the entire grey was taken away... complete.
I suspect that the same rod from a red won't fit?.. or can be "bent" to fit.... I simply don't know.
I'm sure they are pretty universal across the sdd Stromberg range. They superseded the hole and split pin around HQ.
Hi Brett;
I've got a box of carbs in varying stages of pieces let me know if you want me to have a look for you would cost almost nothing to post from WA.
Errol62 wrote: Fri Jan 31, 2020 1:35 pmI'm sure they are pretty universal across the sdd Stromberg range. They superseded the hole and split pin around HQ.
They were changed at the EH, and again at the HQ.
.... damn.... I need to get a life :eugeek:
Thanks Neil. I've sent you a message. Thanks Rosco and Harv for the updates as well.
