wipr arm length
wipr arm length
Can someone help me with the correct length of the wiper arms for the FB EK please? Cheers, Fraze
Re: wipr arm length
Where is my wiper stash??
Re: wipr arm length
Thanks for that Clay, however it is the arm length I am after, not the blade as shown. Have a great New Year! Cheers, Fraze
Re: wipr arm length
Can’t find my arms fraze sorry. Happy New Year mate
- State: SA
Re: wipr arm length
Hey Fraze
This what you are after? These are off the EK Ute Clay and I scrounged bits from. Top arm is 408mm and bottom 480mm (straight line), both measurements pin/pivot to pin. Hope this helps and Clay finds his arms to get that Ute painted!
- BEB2BCDD-0371-41A4-B6FF-DDA8FC3A5449.jpeg (454.04 KiB) Viewed 17458 times
Re: wipr arm length
Thanks for all the tries guys. What I am after is the length of the arm that holds the blade. (The blade being the part in Clay's photo). This arm pushes onto the spindle which is just below the windscreen. My problem is that my car has two different length of arm and i am trying to establish which is the correct length. Thanks, Fraze
Re: wipr arm length
Exactly 11 inches from the end of the wiper arm to the centre of the hinge pin at the spindle endfraze wrote: Thu Jan 02, 2020 7:52 am Thanks for all the tries guys. What I am after is the length of the arm that holds the blade. (The blade being the part in Clay's photo). This arm pushes onto the spindle which is just below the windscreen. My problem is that my car has two different length of arm and i am trying to establish which is the correct length. Thanks, Fraze
Re: wipr arm length
Like this
Re: wipr arm length
there are different parts numbers for fb and ek
Re: wipr arm length
Thanks Blacky, you nailed it! Thats the dimension I was looking for. Cheers, Fraze
