PCV valve
PCV valve
Post by 138 »
I want to fit a PCV valve to my 138 (she smokes a bit at idle through the road draft tube), and would like to know - The best location for the "return" line- I was thinking of drilling and tapping the spacer plate under the carby, and using a screw-in type PCV valve. Also, how is the road draft tube held in? It looks like a push fit, but I haven't yanked on it yet in case it has a retainer or nut on the inside of the side plate.
Re: PCV valve
They are supposed to smoke, leak oil and smell slightly of unburnt fuel... it’s part of their charm :mrgreen:
Don’t tap the carb spacer - the phenolic goes brittle. Remove the inlet manifold, drill and tap the side of the inlet manifold “box” that the carb sits above (if it does not already have a plug in it).
Some walking sticks slip off, others appear to be flared in place. You can’t see the other side of the stick as there is a baffle inside the side plate.
Re: PCV valve
Re: PCV valve
the draft tube should have a tang on the lower part that bolts on to one of the bolts that hold the sump on
Re: PCV valve
I will heartily second what Harv said.
Perhaps I could suggest piston rings instead of a PCV setup :)
Re: PCV valve
Post by 138 »
There is a fitting which feeds the vacuum advance on the distributor, how about a "T" fitting there? I don't have any other holes in the manifold, unless I get to it with the drill.
Re: PCV valve
The vacuum advance port on the carburettor does not connect to manifold vacuum. It only produces vacuum off-idle and at light throttle openings. And the port drillings are tiny, so the flow rate will be next-to-nothing.
Are you using the standard inlet manifold? There should be a threaded plug on the side of the casting below the carburettor.
Also, PCV systems are designed to operate with new engines. They can't cope with the amount of blow-by produced by a worn engine. (Years of driving clagged red motors has taught me that.)
Re: PCV valve
Post by 138 »
Your'e right, I didn't follow the line through properly, and the line I was looking at was the vacuum line for the wipers. I reckon a "T" there might work, the line is 1/4".
Re: PCV valve
Just put the T-piece at the manifold. "Uphill" of the vacuum section of the fuel pump is not a good idea.
Re: PCV valve
Vacuum wipers and pcv
Damn rodders
8)8)8)
Re: PCV valve
Post by 138 »
You been snoopin' over my fence again!!!
