Simba's EK Wagon
Simba
Simba's EK Wagon
Post by Simba »
Hi All,
Recently rejoined the forum as I finally got around to buying my first EK Holden. Always wanted a wagon and have been looking for a project to pop up.
I've got a history in automotive painting and electric work and have rebuilt a fair few motorcycles in my time. Not much in the way of panel beating and rust repair so this is going to be a steep learning curve for me but one I will enjoy.
Anyway here is my new pride and joy:
As it arrived it was rusty as hell, full of water and redback spiders and didn't run.
Simba
Re: Simba's EK Wagon
Post by Simba »
So I have recently found out while stripping the car that it was restored in the late 80's / early 90's. Has a red 186, celica 5 speed, hq disk front end and a shortened vl diff with rear disk brakes. With a bit of a freshen up it starts and drives, only have one brake out of four working though so will need to give that some attention. It looks like a good recipe for a daily driver which is ultimately what I'm after.
The goal is to do a basic restoration to daily driver level adding creature comforts but keeping it as stock looking as possible.
Where I'm at now:
The main concern areas for rust are around the petrol tank, rear windows, drivers side A pillar and under the drivers side rear passenger:
Should be interesting...
Simba
Post by Simba »
All the doors are rusted through so will need to repair or replace them. Got lost of goodies on their way from gumtree. Wheels, orginal steering wheel, trim etc.
Under the passenger seat:
Will attack this first.
Welcome to the forum Simba. Looks like a great project mate. I love wagons. Either the paint colour or interior looks to have been changed at some stage. Can you tell us the body plate details, lower passenger side firewall?
Those rear quarters look challenging. Possibly the passenger A-pillar, sills and floor have been repaired previously, so would be worth having a careful look at these areas. How is the front subframe and area where it bolts to the firewall? These are typical rust areas that may have been repaired previously.
The front suspension may be HR ball joint with HQ uprights and/or brakes fitted. I think HQ and VL hub PCD is different by about 1mm which can cause issues with wheels.
I like the sound of your plan to have a stock looking daily driver and look forward o following your progress.
Clay
Welcome to the forum mate 8) that will keep you out of the pub for a while !!!
Plenty of advice and a good place to start looking for parts here on this forum , don't be scared to ask :thumbsup:
Yes welcome to the forum and welcome to FB EK rust !!
Take your time and enjoy, read lots as there is plenty of info on the net and here to help you along the way.
G'day Simba,
Looks like you've got the bones of a good project there. Keen to watch the progress of your wagon. :thumbsup:
Wagonz iz cool 8) .
Looks to be Paint Number 585-0245 (Strata Blue) and Top Number 585-0246 (Snowcrest White).
Think a bit about the driveline though. If it has a HR front end and is registered, most states will grandfather them. Once they are out of rego, then most states will want an engineers certificate... with all the horrors of collapsible column, demister, retractable seatbelts, 2-speed wipers etc. Sadly, there is little additional work to putting a V8 into one.
Simba
Post by Simba »
Thanks everyone. This forum looks like a great place to post my progress and get advice etc. I'll get a pic of the body tag today and post it up. In regards to the wheels yes I do indeed have different stud patterns on the front and back so I'll have to somehow marry up a set of hq era wheels with some commodore wheels and make them look like Ek wheels :crazy:
Passenger side front subframe is shot too so add that to the list.
I am a bit worried about the engineering side of things. It hasn't been registered since 2001 and I found a modification plate from 1991 in QLD. My guess is that plate holds no validity in NSW, but I could be wrong. I suppose I'll just cross that bridge when I come to it.
I'm hoping to have this ready for the Nationals next year!
Simba
BILLY BLACKARROW
Post by BILLY BLACKARROW »
Hi Simba
I wouldn't worry to much about engeneers as I have found the one I am useing hasn't asked me to do anything that I found anresnable after all it's your safety they are protecting . Where in N.S.W. are you
BILLY :arrow:
BILLY BLACKARROW
Simba
Post by Simba »
That's true. If I have to jump through the engineering hoops then that's OK given it's all a benefit to my safety. I had a minor crash in a 63 falcon that had no seat belts a few years ago and that was quite a wake up call. I'm in Newcastle, Any reasonable Engineers around this area? Good thing is I already have spots for seat belts, a demister and 2 speed wipers so it's on it's way (Kind of). Here's the ID tag Image
Simba
Post by Simba »
Looks like it was Snowcrest White on Garrison Grey
Simba wrote: Tue Sep 18, 2018 9:21 am Looks like it was Snowcrest White on Garrison Grey
Yep.
The Queensland mod-plate will not be accepted in NSW, even if it had rego. The RMS will require a new engineering certificate from a NSW engineer.
Stud pattern is an easy fix - take the axles to a machine shop along with a set of oversize wheel studs which are available from Coventrys or the like , they are still 7/16" thread but with a larger spline . Offset drill the existing stud holes to 4 1/2 " PCD and press the new studs in , job done. You may need to slightly elongate the holes in the rotors but as they are centred on the axle flange this wont be a problem.
Simba
Post by Simba »
Thanks Blacky, great idea.
