Diff rumble
BIGREVNEV
Diff rumble
Post by BIGREVNEV »
I have recently changed from 3.08 to 3.36 diff centre . Reco from Aussie diffs , but i,m not convinced all is well . It’s fine on aceleration & deaceleration but there is a rumble that happens only when there’s no load , in between back off & power on , i figure it must be in the diff as it wasn’t there before , any clues any one ,
Re: Diff rumble
I had a diff rumble like this once and it turned out to be a needle roller from the uni joint getting jammed up when the caps fell off.
When I put the tail shaft back in the uni was a tight fit in the flange, thought nothing of it but it didn't last long.
Did the caps come off when you changed it over ?
BIGREVNEV
Re: Diff rumble
Post by BIGREVNEV »
I think you’re on the money .i dropped both caps but i thought at the time they were still ok . I bett thats it :thumbsup:
