Hi all,
Anyone else have trouble with the original grey motor exhaust manifold leaking, due to corrosion / warping. It looks to be leaking with a new gasket, along the top of the exhaust manifold. Can you machine them flat again?
CC
Exhaust manifold
- State: SA
Re: Exhaust manifold
Hi CC,
Yes had that problem. Tried new gasket then tried copper heat gasket silastic which just blew out after a short run. You can easily fix it yourself. See my post on page two. Post up any other questions you might have.
http://www.fbekholden.com/forum/viewtop ... 8&start=15
Thanks Stephen,
Got to find time to work on the EK
