"new" wheels
"new" wheels
doing a resto on a set of Tasmans , centres are done - just waiting on the hoops to come back from chrome :ebiggrin:
Re: "new" wheels
Do they bolt in?
Going on the ute or sedan?
Re:
Trev wrote:Do they bolt in?
No Trev, they are a weld in centre - there is a piece of steel cast into the outside rear of the spoke.
These will be for the ute , I have a couple more for the front of the sedan :ebiggrin:
Re: "new" wheels
What are the details on the rims Blacky? Have you reused the originals, new rims to original specs or wider? Will you set up the offsets to suit or go stock?
Clay
Re:
Errol62 wrote:What are the details on the rims Blacky? Have you reused the originals, new rims to original specs or wider? Will you set up the offsets to suit or go stock?
Clay
Clay, I bought a set of NOS Skog/Herbert mags with rims a few years ago , they had never been assembled :ebiggrin: then when I went to put them together I found out why - the centres were undersized and would not fit the rims :esad: :esad: :esad: I had a few Tasmans lying around so I thought bugger it I will make a set of Tasmans instead. I am using a pair of the 6" hoops for the front which will be pretty much as per a standard Tasman, I wanted to reverse them and make them deeper dish but the rims I have don't match if you reverse them :thumbsdown: I have a pair of 7" hoops for the rear wheels , will set them up to suit the ute (Torana diff) so they wont fit the sedan (HR diff) . I have a couple more Torana diffs here so might knock one together for the sedan so I can mix and match wheels from both cars.
Re: "new" wheels
Very cool Blacky
mph
Re: "new" wheels
Post by mph »
nice work mate it should come up a treat
FB-Special
Big block 161 :lol:
Holley sniper EFI.
Ek auto column shift.
Lj diff and reverse lights.
WA FB~EK Car Club Member.
fingers
Re: "new" wheels
Post by fingers »
Hey Blacky could ha post a photo of the Skogs please mate ....
Re: "new" wheels
Just like new! :thumbsup:
Re: "new" wheels
fingers wrote:Hey Blacky could ha post a photo of the Skogs please mate ....
They are the same as the ones Thommo had on his FB ? I have only ever seen 2 sets of them apart from mine ...
Re: "new" wheels
like this Bill -
Re: "new" wheels
They look like Cragars.
Re: "new" wheels
yes they do but they are all one piece , no centre cap.
fingers
Re: "new" wheels
Post by fingers »
Thank you ....
Re: "new" wheels
They look great Blacky. Top stuff :thumbsup:
I've got a similar project.. with a set period 'Spyder' mags that need new hoops. One day...
