v6 engine wiring
bematote1
v6 engine wiring
Post by bematote1 »
ok fellas I need help I've got an ek ute with a vn series 2 engine and auto box
I put in an ultimate wiring harness and everyone tells me how easy the VN ECU is to wire up
but I am getting nowhere fast
I do have it turning over
any help please
Re: v6 engine wiring
Firstly - welcome to the forum 8)
Second - you are not giving us much to work with here , can you give us some more info ??? Are you using the EK harness with the VN ECU harness or have you started from scratch ??? Got fuel pressure ? Can you read fault codes ? etc ....
Hi Bematote1
I have done this conversion and wired up my car so as Blacky said give us a bit more detail and I should be able to assist.
Neil H
ekdave1962
Post by ekdave1962 »
hi there i found the guys at delco hacking forum a great help when i wired mine .. including a daughter board to allow usb coms to the ecu which from memory was neeeded to change a few parameters
ekdave1962
Hi Bema
I'm wondering how you are getting on with your wiring I have just had a look at the "Ultimate Wiring harness" website and not sure where your issue may be as I would assume that you are using the original engine harness which should plug straight into your ECU if I remember rightly there is another plug that comes off of the engine harness that the rest of the body harness should then plug into.
As we said before a little more info and we may be able to help mate.
Neil H
