Ht wheels
Rusty EK
Ht wheels
Post by Rusty EK »
Going to look at a set of 14 inch wheels in the morning , is there a easy way to tell between Ht HK ?
Re: Ht wheels
HK have 8 small rectangular slots arranged in 4 pairs of 2 , HT have 4 very narrow long slots
Rusty EK
Re: Ht wheels
Post by Rusty EK »
Well that's to easy , thanks Blacky :thumbsup:
stinky
Re: Ht wheels
Post by stinky »
HT wheels
Re: Ht wheels
Arent they HK Stinky ???
mph
Re: Ht wheels
Post by mph »
Blacky wrote:Arent they HK Stinky ???
Yes hk blacky
FB-Special
Big block 161 :lol:
Holley sniper EFI.
Ek auto column shift.
Lj diff and reverse lights.
WA FB~EK Car Club Member.
Re: Ht wheels
They seem to match Blacky's description for HK?
Rusty EK
Re: Ht wheels
Post by Rusty EK »
Gee boys don't change your minds now , I have already brought them :lol:
mph
Re: Ht wheels
Post by mph »
When i bolted a stock offset hk rim to the front right of the fb with the original drum fb front end the rim rubbed and couldn't push the car from memory :problem:
FB-Special
Big block 161 :lol:
Holley sniper EFI.
Re: Ht wheels
Stinkys are HK! I have HT but LH discs and have no clearance issues.
stinky
Re: Ht wheels
Post by stinky »
Yep, the HT wheels are on it now though :oops:
Re: Ht wheels
I had HTs on the stock hubs of my EK sedan when I first got it. Later one of the centres cracked between the stud holes. Could this have been due to using the EK wheel nuts rather than HT? At the time it was put down to incompatibility with the HR disc hubs I later fitted.
Even though I always liked the idea of using the 14s I was disappointed that the 13" caps wouldn't fit. Recently Jeff Stewart from the FE FC site showed me the 14" rims on his sedan which were made by welding in cut down 13" rim and centre to 14" rims. Clever and legal? I believe they came from Perth and aren't widely available. Wouldn't mind a set with disc brake centres if anyone has any leads. Assuming these are legal then should be able to get local rim works to make some up.
Re: Ht wheels
Probably made by Rob Summerfield if they were made over here .......
http://www.yellowpages.com.au/wa/baldiv ... sting.html
Re: Ht wheels
Cheers Blacky
