fb k section wanted
coupe
fb k section wanted
Post by coupe »
Hi guys im looking for a good fb ek k section subframe in the brissy area. Also a fb ek shell i can cut the firewall out of through to b pillar. Cheers Dan 0432362892
Re: fb k section wanted
Hi Dan
You may be aiming a bit high. Anything bad enough to be cut up is likely to have rusty front floors and sills. Not to mention lower a pillars. I have cut a firewall from an FB to use in my van and I am having to pretty much reconstruct the lower a pillars. The inner and outer sill panels are available as repair sections as you probably know. B pillars are often okay but the only thing that generally survives in between is the tunnel and raised under seat floor.
You should be able to get the firewall and b pillars okay. Good luck.
Clay
