play in idler arm
mr bean
play in idler arm
Post by mr bean »
Hi all
with the ek jacked up when I Turn the left wheel back and forth thier seems to be a lot of play in the idler lever and idler arm joint. What is the best fix.for this.
Cheers Andrew
Re: play in idler arm
wouldn't the simple answer be a new idler arm ???
The pivot bush and pin are usually the culprit and are universal fitment FE to HR. Cheap easy fix last time I did one which is 20 years ago.
mr bean
Post by mr bean »
Thanks guys, wasn, t sure if it was a bush or relplace the whole arm. Anyway I picked one from rare spares $28, looks a bit cheap.
Thanks again.
You'll notice an improvement Rowan?
