Castlemaine Rod Shop Front End
Posted: Mon Jul 04, 2016 3:59 pm
by Clinker42
- image.jpeg (66.64 KiB) Viewed 3979 times
Hi, first, thanks for letting me join.
Picked up an EK sedan on the weekend and just starting work on it. Body is in fantastic condition except for the floor foot wells. Ordered a tunnel from CRS and 4 foot wells from Rare Spares.
Does anyone on here know what and how the brakes are fitted on the Castlemaine Rod Shops custom front ends. When I spoke to them this morning they didn't have a clue on the product they are supplying. They said they where &*#@ discs.
I'm just chasing what model they are to see if I can get a hub for it like they use on the VB - VK Commodores. Hoppers make a &*#@ hub but I have to know what hub CRS are using. If I know I can get a hub for the CRS front end I can fit VT rotors all around and use the hat style on the front and use the hat to set my offset.
Anyone have one or know about them.
Thanks Trevor
Re: Castlemaine Rod Shop Front End
Posted: Mon Jul 04, 2016 4:25 pm
G'day Trevor,
CRS did a variety of spindle/brake combinations - HQ/WB, P76, VT/VZ etc.
As an example, my CRS front end has the standard HR spindles, which CRS modify to take Commodore bearings. They supplied a kit to adapt VN/VP calipers and rotors.
Posted: Mon Jul 04, 2016 5:17 pm
by oz_ek
I take it your referring to the new fabricated CRS front end, not the modified HR version?
Posted: Mon Jul 04, 2016 5:36 pm
by Clinker42
Yes sorry guys, the new fabricated one.
Posted: Mon Jul 04, 2016 5:49 pm
by oz_ek
Do you have a source for the hubs?....There was a bloke on the FE/FC forum making adaptor hubs to fit Commodore brakes/wheels to early Holden stub axles.
Can see why the CRS front end couldn't be fitted with a HQ type stub axle.
Posted: Tue Jul 05, 2016 1:48 pm
by Clinker42
I thought I did but I just rang them and they won't sell them seperate from a kit.
Geez this front end is either too hard or too expensive.
Ok you early Holden experts, what's the best way to get power steering and 300 mm discs and twin piston callipers on an EK. I'd prefer using VT discs and callipers all around as it makes it much easier for engineering.
Can you make a HR front end handle and ride really nice?
Posted: Tue Jul 05, 2016 2:45 pm
by NoMAD
theres a few different companies out there doing fab front ends... try
V6 Conversions
http://www.v6conversions.com.au/
Rod Tech
http://rodtech.com.au/index.php?route=p ... uct_id=648
given em a call and have a chat i'm sure one would accommodate you... budgets probably the only question
Nathan
Posted: Tue Jul 05, 2016 3:06 pm
by Clinker42
Great timing Nathan, just got of the phone with a lovely lady at Rodtech. How good is it to talk to someone who actually knows the product they make and sell.
Definately going with the Rodtech unit. She could even tell me that they can do the bigger BA discs and AU twin spot callipers and they make their own hub to fit it. She even knew what offset wheels I need, what Spring rates I could choose and what power rack was on it. She made grasshoppers and CRS look stupid.
What a pleasant surprise it was, thank you Rodtech.
Posted: Tue Jul 05, 2016 3:18 pm
by oz_ek
Clinker42 wrote:I thought I did but I just rang them and they won't sell them seperate from a kit.
I'm no expert... but,for the price of the CRS front end ($4500) I think you could get all your looking for and spend much less!....There's a thread on this forum where someone is using a VR/VS power steer rack on a HR front end supposedly?
What will be your final rim/tyre combo ?......And have you talked to
Hoppers Stoppers re the brake upgrade?
Hoppers Stoppers. ph 03) 97486950.
Posted: Tue Jul 05, 2016 4:37 pm
by Clinker42
OZEK, yes it's a lot of money I know, but it comes engineered. As soon as you weld on brackets and fit that power steering yourself it needs an engineers certificate. So I presume that will mean a lot of testing, checking bump steer etc etc. at least with this kit the engineer sees the paperwork and just checks I bolted it in correctly. Yes I spoke to hoppers today and they where actually rude. Telling me I can't do this and they won't sell me hubs and I have to do it their way, the guy actually wasn't even listening to what I wanted to do. Told me I can't put &*#@ hubs on an EK front end after I told him the front end I wanted to use has XF discs and spindles. Well I don't deal with people like that. That's why I'm going the RODTECH front end.
