Page 1 of 2
Timing gear set
Posted: Thu Apr 14, 2016 9:46 pm
by Craig Allardyce
Hi everyone, as it states I'm chasing a cast steel timing gear set from Master Engineering in Adelaide.
Not after the Speco ones on Ebay as that's what I'm having problems with.
Thanks in advance.
Re: Timing gear set
Posted: Thu Apr 14, 2016 11:15 pm
by In the Shed
Hi Craig,
I gather Master Eng are still out of stock? I tried to obtain one from them last year but no joy. Good luck.
Regards Stephen
Re: Timing gear set
Posted: Fri Apr 15, 2016 7:06 am
by yaapeet30
Check out Automotive Surplus in Mitchem. When I got a set from them a while ago, I am certain they weren't Speco.
Rod
Re: Timing gear set
Posted: Fri Apr 15, 2016 8:36 am
by Craig Allardyce
In the Shed wrote:Hi Craig,
Regards Stephen
G'day Stephen, I cant even find a phone number for them.
Re: Timing gear set
Posted: Fri Apr 15, 2016 8:38 am
by Craig Allardyce
yaapeet30 wrote:Check out Automotive Surplus in Mitchem. When I got a set from them a while ago, I am certain they weren't Speco.
Rod
Thanks Rod.
Re: Timing gear set
Posted: Fri Apr 15, 2016 3:02 pm
by parisian62
I think the Vic Club used to also keep a few of these in their stock? Maybe PM Rosco or someone form the Vic Club?
Re: Timing gear set
Posted: Fri Apr 15, 2016 6:29 pm
by Craig Allardyce
parisian62 wrote:I think the Vic Club used to also keep a few of these in their stock? Maybe PM Rosco or someone form the Vic Club?
Thanks Stewart. I got onto Bill Reid via fb, just waiting on an answer as to whether I can buy one.
Re: Timing gear set
Posted: Fri Apr 15, 2016 10:46 pm
by In the Shed
Re: Timing gear set
Posted: Sat Apr 16, 2016 12:17 am
Re: Timing gear set
Posted: Sat Apr 16, 2016 9:52 am
by Craig Allardyce
Just to let everyone know Master Engineering has closed its doors. All tooling and patterns were sold off to a guy in NSW......the chase continues.
Re: Timing gear set
Posted: Sat Apr 16, 2016 10:59 am
by collecta
I use another SA local companies grey timing gear sets a bit pricey but all are doing well so far
http://www.jp.com.au/Performance.html JP Engineering
cheers
Scott
Re: Timing gear set
Posted: Tue May 03, 2016 4:52 pm
by Craig Allardyce
Thanks Scott, yes I know of them. The alloy one will be my second choice if I cant get a cast steel gear set.
Re: Timing gear set
Posted: Sat May 14, 2016 7:42 am
by fb cruisin
Craig Allardyce wrote:Hi everyone, as it states I'm chasing a cast steel timing gear set from Master Engineering in Adelaide.
Thanks in advance.
What problems did you have with the Speco one Craig, I'm interested as I have one on mine as well ?
Re: Timing gear set
Posted: Sat May 14, 2016 8:59 am
by Craig Allardyce
fb cruisin wrote:Craig Allardyce wrote:Hi everyone, as it states I'm chasing a cast steel timing gear set from Master Engineering in Adelaide.
Thanks in advance.
I found the helix angle on teeth too tight. Whilst it went in with the correct backlash, it wore to over 010" backlash due to poor tooth contact. The excess backlash then amounted to a noise and vibration at certain rpm and loads that was exacerbated by the billet steel material making a very metallic ringing noise.
Re: Timing gear set
Posted: Mon May 16, 2016 10:26 am
by thropzed
You sure its not the Crank Gear thats worn or cut wrong?
Cheers Theo Z............
