Demister hose to heater rubber mouldings
Looking for some heater box (nasco) to demister hose connectors - have seen them before on eBay but cannot remember the seller - if anyone can help pls post up or PM.
Thank you
Boomer
Re: Demister hose to heater rubber mouldings
Post by Boomer »
G'day Rob,
I bought a set a few weeks back. The sellers name is "Streetlens" but I think he sold out. Good luck
Obsolete Rubbers (Martin Frigo, 2 Glencara St Avondale Heights Victoria 3034, Phone: (03) 93178725, Mobile 0412941799) makes the two rubber demister duct outlets for the earlier Warmarides. These are round (circular) on both the end that holds the hose, and the end that goes into the heater. He makes both the 90º and 45º elbow.
Thanks Harv - I found Martins details from an older thread but it looks like he has no stock and not interested in making more - also out of the heater hose clips for rocker cover.
Worst comes to worst, you can easily make some out of a radiator hose - see around P41 or so of the Guide:
http://www.fbekholden.com/forum/viewtop ... 29&t=12061
can you get by with just the 45 degree ones? he said he might have some of those but definitely no 90's
FJWALLY wrote:can you get by with just the 45 degree ones? he said he might have some of those but definitely no 90's
I reckon you can. The difference in angle is only to allow you to route the demister tubing... just bend the tubing a little different.
ok - worth a try I guess - I danged to pick up some hose which was for MG but looks identical to the original fabric covered tube - should do the job nicely and a fraction of what the greedy one is asking.
