Starter motor
Starter motor
Do red motor starter motors fit a grey?
- Craig Allardyce
- State: VIC
Re: Starter motor
Yep, but only with two mounting bolts in use. Just might pay to check number of teeth on the starter pinion in comparison to be sure. A little edit here Trev. I may have used a red motor flywheel.....cant quite remember, but it was qrey gearbox. So it might be a no depending on pinions/ring gear.
Last edited by Craig Allardyce on Mon Jan 11, 2016 6:21 am, edited 3 times in total.
Re: Starter motor
Thanks Craig.
Re: Starter motor
Im sure the starter will fit in but teeth wont mesh so no good.
Tony
Tony
Re: Starter motor
It's already fitted up and working fine.
Thanks Tony.
Thanks Tony.
