Grey Motor .010" OS Pistons and rings
Craig Allardyce
Post by Craig Allardyce »
As it says, I'm on the hunt for a set of .010" OS Pistons and rings. Have been through the usual with suppliers. Any leads would be appreciated.
Thanks in advance. :thumbsup:
yaapeet30
Re: Grey Motor .010" OS Pistons and rings
Post by yaapeet30 »
Hi Craig,
Not sure if this is what you are after.
http://www.ebay.com.au/itm/HOLDEN-FE-FC ... 2ca23bbf1e
It is only pistons. They are Repco Pistons. I have just had a look in my Repco parts book and I can't find any reference to them. The description doesn't say if they are for a grey or a red.
Rod
Craig Allardyce
Thanks Rod, yep checked that one out. They are in fact 179 pistons - not Grey Motor. The lack of gudgeon pin retainers raised my suspicion. ACL Catalogue confirmed 2087 as 179. 90mm diameter is 3 1/2" which would be into the water jackets. Man you have to be so careful with Ebay.
fingers
Post by fingers »
Hey Graig ....Nason in Dandy had 3 and 1/8 earlier in the year so I guess they still have them .....hope that helps ....Fingers
