seat belt lengths
the rocket
seat belt lengths
Post by the rocket »
Hi all, Could anyone please help me with length they're using for their front and rear seat belts.
I need the measurement from the buckle to the floor on a front bench seat and the same for the rear (centre only).
I don't have mine in a state to measure at the moment. I measured around 360mm from where i think it will go from buckle to the ground using my seat. Does this sound ok??
allowing for the seat to slide as well.
Rick
Re: seat belt lengths
Rick,
If the measurement is critical, I'm guessing you are using fixed-stalk seatbelts? If so, they may protrude quite a bit when you slide the front seat back.
One option is to use the webbing type - Hemco's are adjustable, so that you can shorten them to suit.
I'd measure mine for you, but I'm a fair way from the car.
the rocket
thanks harv,
I'm getting them from seatbeltsolutions in WA. They are a fixed size but made of webbing. They are being made blue webbing with chrome torana style buckles (refurbished) and to Aus/NZ standards with the tag and all. Hemco couldn't do the chrome buckles for me.
Got home last night, and measured my belts from my FB sedan:
front: 290mm
rear: 280mm
nes138
seat belt lengths
Post by nes138 »
I just had mine done by seatbelt solutions for an FC (not inertia) and measured a little longer than that but don't stress as they are adjustable.Image
the rocket
thanks guys
much appreciated harv.
Rick
