Flywheel/Clutch Cover Bolts - Loctite
OldMan's Lacky
Post by OldMan's Lacky »
Does anyone use Loctite Red or Blue when attaching the flywheel or clutch cover bolts or is not necessary for a stock standard grey? Cheers.
Craig Allardyce
Re: Flywheel/Clutch Cover Bolts - Loctite
Post by Craig Allardyce »
Not required. Just make sure all threads and spring washers are in good nick. Tension to specification and you'll be ok.
OldMan's Lacky
Thanks Craig!
