tail light sealing
tail light sealing
It just came to mind that i have all new chrome tail lights to bolt back in but what is the prefered method of sealing the base to the car ?? is there a rubber seal that im unaware of to stop water from leaking through in to the boot
- image.jpg (73.88 KiB) Viewed 12236 times
Re: tail light sealing
sometimes they have a sealer of sorts behind them , which is usually as dry as a chip when you pull them off - it sorta looks like a caulking compound ???
Beutyl Mastic (or however the hell you spell it) was what we used on mine.
As Devilrod said, we did mine that way as well...
Another thing to try and works well is black modelling clay, you can buy from any art supply shop. Once you have bolted the lights in apply the modelling clay to the gap between the light and body with your fingers, than wipe of excess off with wax and grease remover. leaves a very clean neat finish.
Hi,
I've go some butyl mastic ready to seal up the newly chromed tail lights, but I can't work out whether or not to run a bead along the very bottom lip. Does anyone have any thoughts on whether to just seal the sides? The way I figure it, if water gets in through the dust seal holes it might escape between the bottom of the tail light assembly and the lower lip. But then I worried about stuff flicking up from the road, and maybe I need to seal the lower part to stop that getting in?
Iain
Iain
way over thinking it. if you have to: bead all the way around and in between the taillight and indicator housings.
Run the bead all the way around.
Get the stuff everywhere… your hands, the driveway, all over the caulking gun, and at least one painted surface.
Use some kero on a rag to clean it up, and smooth the bits that ooze out of the joint as you tighten the taillights.
Run out of rags, and curse the mastic.
Least, that’s what I do
Factory used a latex gasket originally that sealed around the entire edge.
Thanks guys.
And yep - if something needs to be overthunk - I'm your man.
BTW - I have a couple of tubes of black mastic that I bought a while back, but contacted Selleys to see why you can't get the grey stuff - it turns out there's a global drought of ingredients and they've ceased production of butyl mastic for the moment.
Bugger…..
