One piece door glass
RollinLow
Post by RollinLow »
Gday people Im not sure if anyone has done this before but I am think of doing one piece glass in all 4 doors. I have had a good look and measure and I reckon it can be done, the rear doors looks like it will the hardest as the door lock mech will sit very close to where the window channel will need to sit. I have sourced someone that can make my glass if I supply precut templates. What are everyones thoughts?
Re: One piece door glass
I think you'll find the rears hardest to do. You'll need to allow for the rear dogleg up over the arch as this will limit room for glass. Which may also explain why they were two piece to start with.
RollinLow
Post by RollinLow »
Yeah me and the old man (both with panel trade back ground) had a good look the other night and reckon the fronts will be pretty straight forward. Thought of using the original window channel cut shorter and moved to become the front lower channel. Rears will have to do the same although it will be a very short cut to run down to the to of the arch. May have to sacrifice the rear window not opening fully, but plenty of cars do it. Trickiest bit will be getting it all to clear the rear door lock mech, its going to be close. Getting rubbers to fit right is also going to be a challenge I predict, so I am off to see Bill Thompson Auto Rubbers to see what they can come up with.
it can and has been done on henry parry's EK built by the chop shop, fronts are simple
V8ratrod
Post by V8ratrod »
Check out comaro rear windows as they wind down they then tilt/drop down towards
the front of the car before disappearing as they seem to pivot from the rear of glass/wind winder
How did you go with the rear windows Rollin?
