Dimension needed - standard grey motor valve spring
Can someone please measure up a standard grey motor valve spring for me? I forgot to do so before going on the road for work :oops: , and need the dimension to check some bits for the Norman.
The dimension I need is the diameter of the spring. Needs to be fairly accurate please as I will be reusing them as supercharger relief valve springs.
GreyEJ
Re: Dimension needed - standard grey motor valve spring
Post by GreyEJ »
1.304in Just measuerd
Thankyou - appreciated.
