Unable to select gears, please help!
Posted: Fri Apr 11, 2014 9:06 am
by Jayman
Hi Guys,
I have an FB panelvan with a 179 and Celica 5 speed. It is my everyday driver.
I drove home from work yesterday all fine. Drove the car out of the garage this morning all fine, left the car running in neutral, closed the garage door, and when I hopped in and went to put the car into gear I couldn't! Car changes gears easy when not running. Starts in first gear but wants to creep forward. When I try and select reverse while the car is running it just grinds. Didn't have time to check anything this morning, just grabbed my wife's car and left for work.
I have done a search and haven't had a chance to see if there is fluid in the reservoir. Strange how this happened so quickly. Any help would be appreciated.
Thanks
Re: Unable to select gears, please help!
Posted: Fri Apr 11, 2014 11:24 am
Sounds like a slave cylinder problem to me , I reckon it will be pretty obvious once you have time to look at it properly.
Posted: Fri Apr 11, 2014 12:33 pm
by Jayman
Thanks Blacky, fingers crossed!
Posted: Sun Apr 13, 2014 2:50 pm
by Jayman
Update to this problem.
Replaced slave cylinder today and adjusted the clutch at the slave cylinder. When I adjust it enough to engage the gears(when the motor is running) I now have the clutch slipping. I am pretty certain that I have bled the air out.
Any suggestions would be appreciated.
Thanks
