SBC block hugger headers
Coopa
Post by Coopa »
Has anyone tried SBC block hugger headers or are you better if with the CRS ones that go out the inner guards?
Re: SBC block hugger headers
Coopa,
I went with the CRS fenderwell extractors. They are 4-into-1, 1.65”x1’5” primaries to which I bolted a twin 2½” exhaust with “H” balance pipe. Sounds nice 8) .
Cylinder #8 (closest to driver) will have poorer flow capability due to the extractor design - it needs a tight bend to clear the steering column/rods. Depending on your setup, blockhuggers may well have the same drama. The CRS set bolt up OK, though as you can imagine they cut a pretty fair size hole in the inner guards (which my engineer now wants reinforced). You will need the hex-head extractor bolts to fit them as the holes are too close to the pipes for normal bolts.
Coopa
Post by Coopa »
Thanks Harv it was the guard cutout that was making me think about the block huggers as mine will get driven regularly and we have a lot of gravel roads down hime way I was thinking of all the rubbish that will go up through the hole, might have to look at a shield arrangement to protect from the rubbish coming of the front wheels
(Running a front mount LJ rack to HT column, 305 to VS V8 T5)
Cheers Coopa
