Split in PBR VH 40 diaphragm
Sputzwagon
Post by Sputzwagon »
G'day all,
had my brakes go hard in the pedal and the engine run rough yesterday?? It was what I though..a split in my PBR VH 40 brake booster's diaphragm. :?
With some help from Spaceace and a mechanic mate (Gaz at Kings Point Automotive) I was able to get an new diaphragm sent..(unfortunately it won't arrive here until Monday :thumbsdown: ). So I have done a 'get-me-out-of-trouble' fix, this is good to know for those with these or the VH 44 booster on drum brakes ... Once I had undone the front mount nut ( 1/2") & slid off the small vacuum line on the booster body , I undid the screw & nut off the outer locking ring an so to get to the large diaphragm and prized it off the center of the plunger. (see diagram).
once I found the split (luckily around the outer rim of the diaphragm) I cleaned the split and glued it together with super glue. then put the whole lot back together..and it works! :thumbsup: :clap:
Now remember this is only a temporary fix until I get the new one on Monday.. but it should get everyone else out of a roadside brakedown... (Pun intended). :lol:
Scotty.
Woofto Car Club Member No 2
FATBOY
Re: Split in PBR VH 40 diaphragm
Post by FATBOY »
Hi scotty got one in the main shed next to fridge when u coming down
regards fatboy
you know what you can also do for a temporary side of road fix just disconnect the vacume line from manifold and block it off at the manifold car will run fine you will just have a hard brake pedal :wink:
DOLLER.
Post by DOLLER. »
Who needs brakes! :crazy:
Sputzwagon
True Mick..I've done that..but I LIKE GOOD BRAKES..not "standard-need-Arnie's-right-leg-to-pull-the-car-up" type stuff! :wtf:
Scotty
Sputzwagon wrote:True Mick..I've done that..but I LIKE GOOD BRAKES..
Scotty
what the hell are you doing in an EK then :lol: :lol: :lol:
Sputzwagon
Mick wrote:what the hell are you doing in an EK then :lol: :lol: :lol:
:wtf: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
Scotty.
