Volvo 240 Diff into 61 EK.
GM_1961
Post by GM_1961 »
Dose anyone know if this is right?
And dose anyone know the measurements of the 240?
Thanks guys...
Re: Volvo 240 Diff into 61 EK.
I have a Volvo diff at home , not too sure what its out of - will measure it tonight and see how wide it is.
GM_1961
Post by GM_1961 »
Awesome. If it's close to a EK size diff and is LSD and you want to off load it throw us a price.....
Richo
GM_1961
Post by GM_1961 »
O, and is needs to be disc drake.. :smile22:
Its a disc rear end, not sure if its LSD or not - I got it off someone on the forum years ago , not too sure who now - bourbon has destroyed my memory :econfused:
EKDV8
Post by EKDV8 »
hi! richo if you scroll thru the rest of the pages under driveline there is a number of posts regarding the use of volvo diffs including one from nomad with some pics. if u do go this way tony at classic olden in cannington has the fb-ek leaf spring pad mounts already made up and can modify the diff to suit .and i believe there is a mob over east that can supply the handbrake cable ext to suit. :thumbsup:
GM_1961
Post by GM_1961 »
Thanks for that Jamie, I remember ya said something about a 240 Volvo... Hehee
GM_1961
Post by GM_1961 »
With the Volvo 240 diff the guy I brought it off said early Holden rims will fit it. So dose that mean HQ rims will fit?
I'm hoping so, as I have put off getting it converted ATM because I was think a VN - VS diff would have been a better way to go.
NoMAD
Post by NoMAD »
Early Holden means pre HQ mate... And you'll need to use at least 14's I believe
One of the well sets between HK-T-G is best but can't remember which ones as some have a different offset of the top of my head
Nathan
GM_1961
Post by GM_1961 »
Thanks mate...
